• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Emboss in assembly
    196 Views, 5 Replies
    09-20-2012 03:15 PM
    Is there a way I can use the emboss feature in an assembly?
    We typically laser mark during final assembly and would like to show that as a step in the assembly instructions.
    I typically create a sketch with the text and extrude(cut) in the assembly.
    It works fine for flat surfaces, but cannot do it for other surfaces.
    The one way I can think of doing it would be creating ipart with text and using it in the assembly.
    I would rather not do it this way.  Is there any other way to accomplish this with out altering the components (.ipt)?
    Please use plain text.
    Re: Emboss in assembly
    09-20-2012 03:44 PM in reply to: raju
    Without fully understanding the problem, have you tried derived parts?
    Active Member
    09-22-2012 06:58 PM in reply to: raju
    I know I can use derived parts, but want to avoid doing it.  I do not want to create any new parts.
    Employee
    stanislav.sedlak
    09-24-2012 03:34 AM in reply to: raju
    Unfortunately this is not supported currently. However there's a wishlist logged for this functionality #1458661.
    Stanislav
    mrattray
    09-24-2012 04:59 AM in reply to: raju
    I create a sketch in the flat pattern (I'm assuming sheetmetal) that I use for the actual laser programming, and in the drawing I use the retrieve model sketches command to show the etched lines.
    Mike (not Matt) Rattray
    Product Support
    09-24-2012 07:41 AM in reply to: raju
                Although the emboss command is not available in the assembly features you can create a sketch in the assembly and place text in the sketch. Then you can extrude the text with a cut option. Not as many options as the emboss command but it will do what you want possibility.
