• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    CAD-One
    Accepted Solution
    Emboss File Name on Part
    391 Views, 3 Replies
    01-11-2012 06:04 AM
    In a part, I create a sketch, add annotation Type in the file name. Then create an Emboss feature using this sketch.
    How can I add the file name property to the text. I want the the emboss to update to new file name if I rename the file.
    C1
    Inventor Professional 2013
    Vault Collaboration 2013
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: Emboss File Name on Part
    01-11-2012 07:07 AM in reply to: CAD-One
    Hi CAD-One,
    Mark Randa wrote some iLogic to do this (http://opendesignproject.org/).
    I'm having some trouble getting his link to work, but I've attached an example file using his code, as well as a link to a video of it being set up: http://youtu.be/Y5a8IYyxFLo
    In the example, you can change the part number iProperty and then save the file to run the ilogic rule. The attached file was created in Inventor 2010, in case some one with an older version is interested also.
    Also, I'd look for this to be do-able "out of the box" in a future release of Inventor. :smileywink:
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    CAD-One
    01-13-2012 07:51 AM in reply to: Curtis_Waguespack
    Great help. Thanks
    C1
    New Member
    Mtywtts
    10-23-2012 08:55 AM in reply to: CAD-One
    I was able to get this to work on an ipart that is vaulted. What isn't working for me is running the rule so the appropriate text is visible depending on which instance of the ipart is placed into an assembly. I would think that there should be some way to make the rule run when each of the ifactory parts are generated?
    Marty Watts
    Becker/SMC
    Inventor 2012
