• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Howard, Jeff
    Ellipse trim bug?
    83 Views, 4 Replies
    10-30-2002 09:55 PM
    File in CF.
    What I'm trying to do is set up a sketch with ellipse and radial lines for
    projection to new sketches which will be elliptical segments. The radials are
    projected, an ellipse sketched using the radials and then trimmed. When
    trimmed the ellipse segment goes red (can't solve constraints?).
    Jeff
    Please use plain text.
    *Caldwell, Larry
    Re: Ellipse trim bug?
    10-30-2002 11:17 PM in reply to: *Howard, Jeff
    I'm probably not interpreting what you are doing correctly, but I patterned
    some radial lines, made an ellipse on one and trimmed it. Offset a couple of
    workplanes and projected successive lines to them drawing and trimming the
    ellipses and didn't see any errors. If you want to post what it is you're
    trying to do exactly, I could see what I misunderstood.
    ~Larry
    "Jeff Howard" wrote in message
    news:smileyvery-happy:F055279A9F459D8BB68F5FC4C198765@in.WebX.maYIadrTaRb...
    > File in CF.
    are
    > Thanks,
    > Jeff
    *Caldwell, Larry
    10-30-2002 11:39 PM in reply to: *Howard, Jeff
    Oh ... it was already there. I didn't get the same result. Mine trimmed
    okay. See CF.
    ~Larry
    > File in CF.
    are
    > Thanks,
    > Jeff
    *Autodesk\
    10-31-2002 12:48 AM in reply to: *Howard, Jeff
    I opened your file in the RTM build, and the ellipse segment was green.
    Loren Jahraus
    Autodesk Inventor Workflow Team
    > File in CF.
    are
    > Thanks,
    > Jeff
    *Howard, Jeff
    Re:
    10-31-2002 04:31 AM in reply to: *Howard, Jeff
    Thanks for looking, guys.
    That's good news, Loren.
    Jeff
    "Loren Jahraus (Autodesk)" wrote in message
    news:smileyvery-happy:3C56529BA8E3B989C808A084367D544@in.WebX.maYIadrTaRb...
    Loren Jahraus
