• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Anthony
    Elevation symbol
    187 Views, 6 Replies
    10-24-2012 07:35 AM
    I'm looking for an elevation marker to add to an Inventor drawing, I need something similar to what is currently available in AutoCAD's design centre. Does anyone know if there is one available in Inventor 2013 ?
    Please use plain text.
    Ryan.Martinez
    Re: Elevation symbol
    10-24-2012 09:16 AM in reply to: Anthony
    You could create your own sketched symbol. see this pdf
    http://download.autodesk.com/us/inventorprofessional/pdf/SketchedSymbols_stacking.pdf
    Product Design Suite 2013
    Anthony
    10-24-2012 09:20 AM in reply to: Ryan.Martinez
    So Inventor does not have a library of symbols for use like in AutoCAD then ? Thanks for your PDF link, to me it seems like placing an elevation symbol (for example) into a drawing should take seconds without the need to spend unnecessary time creating the symbol myself ? ? It would be good to see Autodesk address this one for the next release.
    Ryan.Martinez
    10-24-2012 09:22 AM in reply to: Anthony
    create it once in your template file and it will be there everytime you use that template to create a drawing.
    Ryan.Martinez
    10-24-2012 09:25 AM in reply to: Ryan.Martinez
    You can insert acad drawings into a sketch. So you wouldn't even have to draw it. Just save what you want in autocad then import it into inventor.
    Anthony
    Thanks yes, I still think the whole idea of a standard annotation and architectural symbols library being completely absent from Inventor needs addressing - a symbols library should be available as standard with the option to add to this with custom sketched symbols as you have suggested.
    Ryan.Martinez
    10-24-2012 09:29 AM in reply to: Anthony
    I see your point but inventor is a mechanical design tool, not architectural. Maybe the factory design package or revit it would have the symbols your looking for, just a guess.
