Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Edits are not allowed on this file
- Highlight
- Email to a Friend
I decided to delete the red inventor files in the libraries folder. I deleted one and tried it. Still got he error. Then I went back and deleted the other. The errors went away. I placed a part and saved the file. It worked fine. Do I need to add the library path back in? I figure it's there for a reason and I'll find out the hard way. I don't want to do mare damage.
- Highlight
- Email to a Friend
No you don't need a library path. The reason for Libraries is to make the parts read-only. If you are working on a project and design a number of parts for that project. Another project comes along and you realize that you can use some of the parts from the first project, it would then be wise to add the folder/directory in which the first project parts reside as a directory. This still allows you to use the parts but not accidentally edit the parts.
IV2014.1 PDSU / Sim Mech 2014 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 314.07
SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
- Highlight
- Email to a Friend
I just went to place a part and got the attached message. What do I do with this? This may have been the part that got things messed up before. Other parts don't ask for the location. The part is in the correct folder. What is a proxy file?
- Highlight
- Email to a Friend
Is this file in the same directory that is your work directory?
Haven't delt with DWG Mechanical drawings in so long I forget all the details.
Win7-64
- Highlight
- Email to a Friend
Yes, I downloaded it from a 3D parts site and added it to the work directory. It's a servo motor I would like to use in the model. They didn't have the correct format, but I have been told that Inventor can deal with lots of formats. Maybe I'll go back and get the Solidworks format and see what that does.
- Highlight
- Email to a Friend
The Solidworks version works fine. So It may be a compatibility issue.
- Highlight
- Email to a Friend
You might need to open this part in Inventor first, which do the conversion and save, rather than trying to place it in a assembly first.
Win7-64
