• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    kaptenmjau
    Edit mirror in sketch
    92 Views, 2 Replies
    01-07-2013 07:14 AM
    Hi
    If I create circle and then mirror that cicle in the sketch. How can I then edit that mirror?
    When I create pattern in sketch I  can edit pattern afterward but cant figure how to edit mirror (except deleting constrains).
    Is there way to do it?
    Please use plain text.
    *Pro
    Re: Edit mirror in sketch
    01-07-2013 10:49 AM in reply to: kaptenmjau
    Can you give more detail or post a file illustrating the difficulty you're having?  I'm not understanding how one  edits a mirror feature? And let us know what version of Inventor you're using, please.
    Valued Contributor
    01-07-2013 11:10 AM in reply to: kaptenmjau
    If you want to mirror your geometry, and plan to make changes to it later (for example, if it's a mirrored circle right now, but you might change it later to a mirrored semicircle with a rectangular cutout in the middle), it's best to just make the sketch contain one half of the mirror, then after you extrude/revolve the shape, mirror the feature itself.  That way you don’t have to make changes to duplicate copies of your sketch geometry.
    It is also good practice to array your features at the part level, rather than at sketch level  The only reason the sketch-level array has an "edit" option is so you can change the number of instances, the space between instances,  or to suppress specific instances of your geometry.  None of these options would even be applicable in the case of a mirror.
    When you use the mirror command in a sketch, it is literally just making a copy of the sketch geometry and automatically applying symmetric constraints.
    -Autodesk Inventor Professional 2012
