• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Edit a read only file in the library
    406 Views, 4 Replies
    10-13-2010 04:17 AM
    I wish to edit a file in the library   usig Inventor 2011 --  this is shown as read only
    is this possible?   If so, how do I go about it?
    Please use plain text.
    Valued Mentor
    jclaidler
    Re: Edit a read only file in the library
    10-13-2010 04:41 AM in reply to: AllanCheetham8388
    Set a project active that doesn't designate that folder as a library.
    _______________________________________________________________
    ITO - Application Management
    Factory Design Suite Ultimate 2012
    AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
    Distinguished Mentor
    10-13-2010 05:28 AM in reply to: jclaidler
    OR move the file to a different folder, make changes, move back
    Member
    10-18-2010 04:12 AM in reply to: jclaidler
    Many thanks -- a great help
    Allan
    Member
    10-18-2010 04:13 AM in reply to: rdyson
    Many thanks  for you help
    Allan
