• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    rhasell
    Re: Edit Extrusion, OK button Greyed out
    10-17-2012 04:11 PM in reply to: Yijiang.Cai
    Thank you
    This issue is not high on my priority list, it was just something that crops up every now and again, and I was hoping that someone else had experienced it, and possibly had a solution or an explanation as to why it happens.
    If I could understand why it happens, I will try to avoid it while designing, probably something silly that I am doing with the workflow, esp considering that I had to modify the part a few times, and added cuts out of order.
    Thanks once again.
    Regards
    Reg
    Autodesk Product Design Suite Premium 2013 sp1.1 (1)
    Intel Core i7 (950@3.07GHz)
    Windows 7x64 (Home)
    12GB Ram
    Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
    Please use plain text.
    Employee
    10-31-2012 01:52 AM in reply to: rhasell
    Hi Reg,
    We take much investigation on this behavior, and it is a known issue for us. When looking into the extrusion, you will find that the key factor is that the symmetric flip direction is used for extrusion cut. For this issue, the reason why is pretty simple. Edit the extrude feature and change extent from All to Distance, you will see the distance value is set to zero, which is illegitimate. As a result, the dialog does not like the condition and then greys out the OK button. To fix the issue, you could have two choices.
    Choice A: When switching extents type from Distance to All, simply give a meaningful value like 1mm or 1in (default value), instead of zero.
    Choice B: Do not check for Distance value when extents type is set to All.
    Generally Choice A would be a better solution and easier to implement, since any value Inventor sets should be meaningful.
    River Cai
    Quality Assurance Team
    Autodesk, Inc.
    rhasell
    10-31-2012 04:02 PM in reply to: Yijiang.Cai
    Thank you for taking the time to debug the error.
    I thought I was going mad, as it was quite difficult to re-produce the fault in another model, so I guess it was something in my workflow.
    I am happy with the solution, at least I know what to do if it goes pear shaped again.
    Regards
    Reg
    Windows 7x64 (Home)
    12GB Ram
