Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Edit Extrusion, OK button Greyed out
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi all
This has been bugging me for a while now and I am now looking for some help.
Whenever I edit an Extrude 'cut' feature,(eg: To Add or remove a profile), the OK button is greyed out and no matter what I do, I can't get it back.
The only way to edit the extrusion is to:
Shift EOP
Delete the extrusion
Recreate the extrusion.
Shift EOP
fix errors if any.
Any sugestions?
Reg
Autodesk Product Design Suite Premium 2013 sp1.1 (1)
Intel Core i7 (950@3.07GHz)
Windows 7x64 (Home)
12GB Ram
Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
Re: Edit Extrusion, OK button Greyed out
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Based on the workflow or steps you provided, I can't reproduce this behavior. So could you attach the dataset or image for more details?
River Cai
Quality Assurance Team
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi River Cai
Thank you for responding.
One thing I have discovered, is that if there is something hanging off the extrusion, eg, projected geometry, it will not work.
Please See attached file.
Thank you.
Reg
Windows 7x64 (Home)
12GB Ram
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Maybe I did not catch the key idea here, and it is not reproducible using the dataset you attached. Could you give us more steps about the workflow you have done?
River Cai
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I too tried to reproduce the issue and everything worked as expected for me.
But I might have been confused by your model.
In education we often give tests with something called "distractors". These distractors are additional "information" that really have nothing to do with the problem. In other contexts it might be termed "noise". I'm not sure I haven't been distracted from seeing the problem by a distractor. In the attached image can the problem be reproduced without these features?
Can you reproduce the issue is a very simple file of an extruded rectangle and an extrude cut?
When I edit one of your Extrude - Cuts with a change that actually changes the condition of the model - the button becomes available.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In the file you posted, are you trying to edit Extrusion11, changing the cut profile fom Sketch2 to Sketch14? If so, I experienced the same thing that you did-- after deselecting the existing profile and picking the new one, OK was not available (and the preview did not correctly reflect the extrusion options (through all, symmetric). However, if I made any changes to these options, then changed back, all behaved as expected.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I must admit, not some of my best work, the simple design has been modified at least 4 times, (engineering drawings going live without a proper design foundation.)
hense the scrappy work. The reason for the request was that the client has made another change, and. I was not able to edit the extrusions.
I will make a smaller part tomorrow and post it, if I get the error and you guys don't, it will naturally indicate an issue on my PC.
As a matter of interest, there is a lonely extrude in the middle of the tree, just above a shared sketch, edit it, the OK button will not activate at all.
Reg
Windows 7x64 (Home)
12GB Ram
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Does it have a name, ie Extrude2?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Sorry, I was mobile.
It was extrusion 14.
I will make a new part to ease the simulation.
Reg
Windows 7x64 (Home)
12GB Ram
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Based on the sketch name and workflow, I retry it. And the behavior you talked can be seen when editing Extrusion 14, it looks interesting, but when changing the extents from All to Distance to All, and make the flip direction right, it will work fine. Anyway this issue has been logged as 1476442 in our tracking system.
River Cai
