• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    rhasell
    Edit Extrusion, OK button Greyed out
    344 Views, 12 Replies
    10-15-2012 06:30 PM
    Hi all
    This has been bugging me for a while now and I am now looking for some help.
    Whenever I edit an Extrude 'cut' feature,(eg: To Add or remove a profile), the OK button is greyed out and no matter what I do, I can't get it back.
    The only way to edit the extrusion is to:
    Shift EOP
    Delete the extrusion
    Recreate the extrusion.
    Shift EOP
    fix errors if any.
    Any sugestions?
    Regards
    Reg
    Autodesk Product Design Suite Premium 2013 sp1.1 (1)
    Intel Core i7 (950@3.07GHz)
    Windows 7x64 (Home)
    12GB Ram
    Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
    Please use plain text.
    Employee
    Re: Edit Extrusion, OK button Greyed out
    10-15-2012 07:59 PM in reply to: rhasell
    Based on the workflow or steps you provided, I can't reproduce this behavior. So could you attach the dataset or image for more details?
    River Cai
    Quality Assurance Team
    rhasell
    10-16-2012 12:22 AM in reply to: Yijiang.Cai
    Hi River Cai
    Thank you for responding.
    One thing I have discovered, is that if there is something hanging off the extrusion, eg, projected geometry, it will not work.
    Please See attached file.
    Thank you.
    Regards
    Reg
    Windows 7x64 (Home)
    12GB Ram
    Employee
    10-16-2012 12:58 AM in reply to: rhasell
    Maybe I did not catch the key idea here, and it is not reproducible using the dataset you attached. Could you give us more steps about the workflow you have done?
    River Cai
    10-16-2012 04:40 AM in reply to: rhasell
    I too tried to reproduce the issue and everything worked as expected for me.
    But I might have been confused by your model.
    In education we often give tests with something called "distractors".  These distractors are additional "information" that really have nothing to do with the problem.  In other contexts it might be termed "noise".  I'm not sure I haven't been distracted from seeing the problem by a distractor.  In the attached image can the problem be reproduced without these features?
    Can you reproduce the issue is a very simple file of an extruded rectangle and an extrude cut?
    When I edit one of your Extrude - Cuts with a change that actually changes the condition of the model - the button becomes available.
    *Pro
    10-16-2012 04:59 AM in reply to: rhasell
    In the file you posted, are you trying to edit Extrusion11, changing the cut profile fom Sketch2 to Sketch14?  If so, I experienced the same thing that you did-- after deselecting the existing profile and picking the new one, OK was not available (and the preview did not correctly reflect the extrusion options (through all, symmetric).  However, if I made any changes to these options, then changed back, all behaved as expected.
    rhasell
    10-16-2012 05:08 AM in reply to: rhasell
    Thanks guys.
    I must admit, not some of my best work, the simple design has been modified at least 4 times, (engineering drawings going live without a proper design foundation.)
    hense the scrappy work. The reason for the request was that the client has made another change, and. I was not able to edit the extrusions.
    I will make a smaller part tomorrow and post it, if I get the error and you guys don't, it will naturally indicate an issue on my PC.
    As a matter of interest, there is a lonely extrude in the middle of the tree, just above a shared sketch, edit it, the OK button will not activate at all.
    Regards
    Reg
    Windows 7x64 (Home)
    12GB Ram
    10-16-2012 06:02 AM in reply to: rhasell
    Does it have a name, ie Extrude2?
    rhasell
    10-16-2012 04:18 PM in reply to: JDMather
    Hi Sorry, I was mobile.
    It was extrusion 14.
    I will make a new part to ease the simulation.
    Regards
    Reg
    Windows 7x64 (Home)
    12GB Ram
    Employee
    10-16-2012 10:27 PM in reply to: rhasell
    Based on the sketch name and workflow, I retry it. And the behavior you talked can be seen when editing Extrusion 14, it looks interesting, but when changing the extents from All to Distance to All, and make the flip direction right, it will work fine. Anyway this issue has been logged as 1476442 in our tracking system.
    River Cai
