• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Distinguished Contributor
    Edit Excel
    215 Views, 5 Replies
    12-02-2011 11:46 AM
    I am using Inventor 2011.  I have an embedded Excel file with 7 rows.  If I edit the the excel object and add two more rows then go back to inventor, it only displays 7 rows instead of 9.  Any ideas to display all rows?
    Please use plain text.
    *Expert Elite*
    Re: Edit Excel
    12-02-2011 01:20 PM in reply to: cadcamm99
    yep.. Delete the table and reinsert it.. (I always use paste special for what its worth)
    Changes to existing rows/columns update no problem.. But add a row and you need to delete/reinsert..
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    s.mutschler
    Re: Edit Excel
    12-04-2011 09:38 AM in reply to: cadcamm99
    This behavior is intentional relative to "embedded" Excel parameter tables.  If you use the "link" option instead of "embed", the table is maintained "external" to your part and any edits or extensions to that table will appear in your part (without having to delete and re-embed the table).
    *Expert Elite*
    Re: Edit Excel
    12-05-2011 05:33 AM in reply to: s.mutschler
    You make it sound so simple/foolproof.
    Clearly you've never actually tried it in Inventor before.You will learn.
    Windows 7 64 bit
    Re: Edit Excel
    12-06-2011 07:34 AM in reply to: s.mutschler
    I was trying to avoid linking it because I have many drawings that use this table format and I didn't want to have to checkin all the excel files into Vault.  I wanted to use the table command in Inventor but I cannot format it the I want to so that is why I am using excel.
    s.mutschler
    Re: Edit Excel
    12-06-2011 11:36 AM in reply to: cadcamm99
    Ahhh.  Understood.  I missed the Vault management requirement and was referring only to the use of an Excel table to hold part parameters, not embedded OLE objects in part sketches.  In our case, the Link option is convenient when we want to attach the same Excel parameters table to multiple sub-parts.  (Files must be in the same work path as the related parts to avoid unwanted re-linkage prompts.)
    We also often insert and display external Excel tables in Inventor (2012) drawings, in their entirety. Such tables automatically reflect current Excel file content (when the drawing is next opened).
    (P.S. We do not use Vault.  We are using MS Exhange for storage and check-out control of collaboration project files, including Excel parameter tables, albeit we are a small team with few collisions.)
