• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Edit Dimension Dialog
    728 Views, 11 Replies
    09-01-2010 06:50 AM
    I recently had to uninstall / re-install my Inventor (2009).  Before I uninstalled, when I placed a dimension in my drawing the edit dimension dialog popped up and I could add text, tol etc... After I re-installed, I have lost this function.  Where did it go?
    Thank you very much
    Mark Smith
    Distinguished Mentor
    -niels-
    Re: Edit Dimension Dialog
    09-01-2010 07:18 AM in reply to: MarkSmith9762
    Is the "edit dimension when created" checkbox still checked?
    (In Application options on the "drawing" tab)
    Using IV2013 Pro, Win7-64bit
    ****Sage
    09-01-2010 07:34 AM in reply to: -niels-
    ...or Sketch tab
    ....or right click while in dimension in sketch.
    Autodesk Inventor Certified Professional
    Inventor Professional 2012 Edu 32-bit
    Still waiting for -Draft option on any Rib feature. -Properties Painter.
    Still wondering why Edit Form is above Edit Feature on RMB?
    Active Contributor
    09-01-2010 09:03 AM in reply to: -niels-
    This check box does not show up on my system. (2009 sp2)
    As far as sketch and modeling, the dimension can be edited upon placement.  Only in the drawing environment have I lost this functionality.
    09-01-2010 10:19 AM in reply to: MarkSmith9762
    Can you post a shot of your application options, drawing tab?
    I don't have 2009 installed here anymore.
    John Retzlaff
    Active Contributor
    09-01-2010 10:23 AM in reply to: john.retzlaff
    As requested, here is a shot of the drawing tab in my application options.
    Mark
    09-01-2010 10:25 AM in reply to: MarkSmith9762
    If you right click on a dimension in a drawing and select edit, is there a box for "edit dimension when created" ?
    John Retzlaff
    Active Contributor
    09-01-2010 11:27 AM in reply to: john.retzlaff
    No, there is not.
    Mark
    -niels-
    09-01-2010 11:20 PM in reply to: MarkSmith9762
     You said you had to uninstall then reinstall inventor...
    I can't check atm, but could it be that that functionality was added with a subscription bonus pack?
    Did you reinstall that too?
    Active Contributor
    09-02-2010 04:18 AM in reply to: -niels-
    Attached is a screen shot of the service packs and bonus packs I installed.
    Mark
