• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Massey, W
    Edges in shaded views?
    65 Views, 8 Replies
    11-19-2002 04:49 AM
    In INV 5.3 IDWs. Couldn't you control the display of edges of shaded views?
    I thought there was a check box for it. Was this option removed in INV 6?
    Wayne
    Please use plain text.
    *Jayabal, Sanjay
    Re: Edges in shaded views?
    11-20-2002 02:20 AM in reply to: *Massey, W
    Wayne,
    You can turn this off from Tools->Application options->Display tab. Uncheck
    the Edge display under "Active" for shaded display.
    -Sanjay.
    "W Massey" wrote in message
    news:B5CCC2E0049F6F0D5638C17873E59D27@in.WebX.maYIadrTaRb...
    views?
    > Thanks,
    > Wayne
    *Rasmussen, Ed
    Re:
    11-20-2002 02:32 AM in reply to: *Massey, W
    Unchecking the Edge display under Active for Shaded Display does not remove
    the heavy Cartoon lines in my shaded views. Are there some combination of
    settings that will work, or is it wait for SP2?
    Ed R
    "Sanjay Jayabal" wrote in message
    news:smileyvery-happy:7A99B71B5C959D4B1313D1561525A6B@in.WebX.maYIadrTaRb...
    > Wayne,
    Uncheck
    > -Sanjay.
    > views?
    6?
    > > Thanks,
    > > Wayne
    *Rennick, Alan
    Re:
    11-20-2002 02:45 AM in reply to: *Massey, W
    If you RMB>Edit View, there is an Options tab which has an option to uncheck
    tangent edges, but it's always grayed out if I'm making the view shaded -
    anyone else seeing this?
    "Ed Rasmussen" wrote in message
    news:B2F0B435E535384D71BB6D16B5B9FF25@in.WebX.maYIadrTaRb...
    remove
    > Ed R
    > > Wayne,
    > Uncheck
    > > -Sanjay.
    > > views?
    > 6?
    > > > Thanks,
    > > > Wayne
    *Rasmussen, Ed
    Re:
    11-20-2002 02:54 AM in reply to: *Massey, W
    It is grayed out on mine as well, not only for editing the view, but also
    when placing a new shaded view.
    Ed R
    "Alan Rennick" wrote in message
    news:0D2C5E4FDED36B8F7597B22E79DEA60D@in.WebX.maYIadrTaRb...
    uncheck
    > remove
    of
    > > Ed R
    > > > Wayne,
    > > Uncheck
    > > > -Sanjay.
    > > > views?
    INV
    > > 6?
    > > > > Thanks,
    > > > > Wayne
    *Jayabal, Sanjay
    Re:
    11-20-2002 03:01 AM in reply to: *Massey, W
    Hi Ed,
    Can you give me a data set that shows these cartoon lines? Thanks!
    -Sanjay Jayabal
    remove
    > Ed R
    > > Wayne,
    > Uncheck
    > > -Sanjay.
    > > views?
    > 6?
    > > > Thanks,
    > > > Wayne
    *Dotson, Sean
    Re:
    11-20-2002 03:04 AM in reply to: *Massey, W
    I proposed this as a bug right before SP1 came out. Not sure what became of
    it.
    Sean Dotson, PE
    http://www.sdotson.com
    ...sleep is for the weak..
    news:0928B2641F6397B7BF08A940D860D2D9@in.WebX.maYIadrTaRb...
    > Ed R
    > uncheck
    shaded -
    > > remove
    combination
    > of
    > > > Ed R
    > > > > Wayne,
    > > > Uncheck
    > > > > -Sanjay.
    shaded
    > > > > views?
    > INV
    > > > 6?
    > > > > > Thanks,
    > > > > > Wayne
    *Rasmussen, Ed
    Re:
    11-20-2002 05:40 AM in reply to: *Massey, W
    Sanjay,
    I just emailed you an example of one of the drawing files that shows the
    problem. Thanks for your interest.
    Ed R
    news:30B8BEF731234CE9D4C2DD4641F8170E@in.WebX.maYIadrTaRb...
    > Hi Ed,
    > -Sanjay Jayabal
    > remove
    of
    > > Ed R
    > > > Wayne,
    > > Uncheck
    > > > -Sanjay.
    > > > views?
    INV
    > > 6?
    > > > > Thanks,
    > > > > Wayne
    *Rennick, Alan
    Re:
    11-20-2002 06:42 AM in reply to: *Massey, W
    Urg, I suppose it's time to re-propose it, then!
    Maybe it will be addressed with the problem Ed's seeing too?
    "Sean Dotson" wrote in message
    news:516E415576A4E6D6AEEC9D4C40A34D10@in.WebX.maYIadrTaRb...
    of
    > it.
    > Sean Dotson, PE
