Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
EXPORT TO DWG ILOGIC RULE DOES NOT WORK
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: EXPORT TO DWG ILOGIC RULE DOES NOT WORK
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I had another customer with a similar problem and I logged the issue with development.
I am still waiting for them to update me.
I think the problem is the Add-in ID but I am not 100% sure.
Jon Dean
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Rthapa,
Your iLogic code works. I tried the following steps.
- Start inventor 2012.
- New an idw and save it
- Create a ilogic rule.
- Paste the ilogic code (in the diagnosis window) to the code window.
- Make sure the C:\temp\DWGout.ini exist.
- Run the rule.
Result: The dwg can be generated correctly.
Can you verify if the ini file ("C:\temp\DWGout.ini" ) referenced in your code exist? Expection will be thrown if it doesn't exist.
If the problem still exists on your build, could you upload a problematic idw with the rule and the screenshot for the error message? It will help a lot to triage the issue.
Jeffrey Sun
SW Engineer
Manufacturing Industry Group
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You have created this thread twice now.
Please add your comments to the original forum request.
Jon.
Jon Dean
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Jeffrey.Sun,
You are awesome. Your suggestion worked.
My original IDW template was migrated from Inventor 2011 to Inventor 2012 with the rules already embeded.
With your suggestion, I created a new blank IDW template with no rules then added the same old rule in it. It works like a charm now.
Somehow migrating old template was failing.
Yeh! Off to the races.
Raj
