• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    EXPORT INVENTOR FILES AS STEP FILES
    454 Views, 3 Replies
    12-20-2012 03:10 AM
    hello inventor gurus
    i export  inventor 2013  files  as  STEP files,
    but  instead of STEP files  i get
    3DSMAXDESIGN  BI-PED STEP files.
    when i open these 3DSMAXDESIGN BI-PED
    STEP files  in inventor  the 3d models are not
    there ???
    any clues would assist.
    pumpmanplee
    Please use plain text.
    Distinguished Mentor
    Re: EXPORT INVENTOR FILES AS STEP FILES
    12-20-2012 05:11 AM in reply to: PUMPMANPLEE
    Can you post one of the stp files?
    John Retzlaff
    *Expert Elite*
    12-20-2012 09:39 AM in reply to: PUMPMANPLEE
    Make a 1mx1mx1m cube.
    Save as stp.
    Attach the ipt and stp files here.
    Inventor Professional 2014 Edu 64-bit
    Employee
    12-20-2012 08:05 PM in reply to: PUMPMANPLEE
    Hi PUMPMANPLEE,
    Thanks for your report !
    I suppose you use Inventor 2013 to create model and then export it to STEP format and from your description it seems nothing is imported. I need to check if your exported STEP file is good or corrupt if you can post your files here as JD's suggestion or directly contact me via Hongyuan.Li@autodesk.com .
    Kevin Li
    Quality Assurance Team
    Autodesk, Inc.
