• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    EXISTING INVENTOR FILES WILL NOT OPEN IN SAME VERSION
    158 Views, 5 Replies
    10-05-2012 07:19 AM
    Existing Inventor files will not open in the same version of Inventor in which they were created on the same pc.
    The error message reads 'database schema is newer than this version of software'
    A sample file is attached. Is there an answer to this other than having an expensive upgrade???
    Please use plain text.
    Distinguished Mentor
    ampster
    Re: EXISTING INVENTOR FILES WILL NOT OPEN IN SAME VERSION
    10-05-2012 07:34 AM in reply to: edwardtg
    knowing what version you are using would help.
    Member
    10-05-2012 07:45 AM in reply to: edwardtg
    THE VERSION WE ARE USING IS 2011 - Does this make a difference? We have never used a later version to create files.
    *Expert Elite*
    10-05-2012 07:52 AM in reply to: edwardtg
    We're on 2011 and it opened fine here.
    Distinguished Contributor
    Ryan.Martinez
    10-05-2012 07:56 AM in reply to: edwardtg
    Try a repair install/reinstall?
    Product Design Suite 2013
    ampster
    10-05-2012 08:50 AM in reply to: edwardtg
    Since you provided a file for others to download and attempt to open...
    Think about it...
    If I'm on 2010, why should I waste my time and download your file just to see the same msg you are getting?
    Does that help you?
    That's the reason I won't bother downloading anything unless the version is stated.
    Yes, it makes a difference.
    http://forums.autodesk.com/t5/Autodesk-Inventor/For-the-new-guy-s-in-the-discussion-group/m-p/363646...
    I for one avoid the sig line.  If I have a question I'll post what version I'm using at the time I post the question.
