• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    caldun
    Driven Arc Length Dimension and Rebuild Error
    144 Views, 10 Replies
    12-06-2012 06:18 AM
    I'm trying to use the new arc length dimension feature in Inventor 2013 and I am having some trouble. After I apply a driven arc length dimension to a fully constrained sketch and then put user dimension in a user parameter I get an error when I rebuild the part. The error states the the dimension can not be solved.
    Please use plain text.
    Valued Contributor
    Re: Driven Arc Length Dimension and Rebuild Error
    12-06-2012 06:53 AM in reply to: caldun
    I'm getting a resolve link error.  It's looking for the C03_S25_Adv Skeleton.ipt
    Can you attach that file as well?
    Eric
    Please select "Accept as Solution" if this answers your question.
    caldun
    12-06-2012 06:57 AM in reply to: caldun
    Valued Contributor
    12-06-2012 07:20 AM in reply to: caldun
    I guess I don't understand what you are trying to do.  I don't see any errors.  I see your user parameter "Length" is a sum of 5 other reference parameters.  How are you trying to use the "Length" parameter?
    Eric
    caldun
    12-06-2012 07:32 AM in reply to: EScales
    As the shape of the pipe is changed in the skeleton the driven parameters update and the overall length of the pipe then updates automatically which is used for a variety of purposes outside of Inventor. The issue is whenever I click the rebuild button inventor tells me that the driven dimensions can no longer be calculated, which makes no sense because they work fine prior to 'rebuilding'. This problem does not occur if I take the driven arc length dimensions out of the calculated 'Length' user parameter.
    Valued Contributor
    12-06-2012 07:53 AM in reply to: caldun
    Ok, so I got an error when I did the update this time.  When I read the error, it note a problem with CR Sweep Path in the C03_25_Adv Skeleton.ipt
    I opened the skeleton part and edited the CR Sweep Path sketch and I noticed the Design Doctor (red cross in the quick access toolbar) was highlighted.  I clicked through the dialog boxes and it show me a couple of dimensions that it said could not be solved.  I'm not sure why, but all I did was edit the dimension that I have circled below.  I didn't even change anything, just open the edit dialog box and click ok and it corrected it.  I tried changing a couple dimensions in the Pole 2 YZ Layout sketch and then went back to the Pole part and did an update.  It worked this time.  Strange, but it seemed to fix it.
    Eric
    caldun
    12-06-2012 07:58 AM in reply to: EScales
    What happens when you "rebuild" the C03_S25_Adv Pole2.ipt file? Do you get an error in Sketch3?
    Valued Contributor
    12-06-2012 08:05 AM in reply to: caldun
    Yes, I did get an error in Sketch3.  I edited the sketch and deleted the 3 arc length dimensions and placed them again and finished the sketch.  I went back to the skeleton and tried changing the dimensions a couple of times and each time I went back to the pole part and did a rebuild, it updated and worked ok.
    Eric
    caldun
    12-06-2012 09:03 AM in reply to: EScales
    Okay, after you deleted the arc dimensions and replaced them, did you add the new dimensions to the Length parameter before you did a rebuild? And still had no problems?
    Valued Contributor
    12-06-2012 10:25 AM in reply to: caldun
    Ahhh...I forgot that part.  Yep, you're right.  I'm getting the error again after replacing the dimensions in the Length parameter.  It only seems to be the arc length dimensions that have a problem.  The straight sections at the top and bottom are fine.
    Eric
