Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Drawing view rotation
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Everyone
Is it possible to rotate a view? I have a rectangular part that has the ends cut at an angle. The part was created on an angle, not squared with the planes as you would do for a create in place. I want to lay it flat to dimension it. I need to rotate the view so my part is horizontal on my drawing. Is there a way to do that?
Randy
Inventor 2013
Windows 7
Re: Drawing view rotation
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi rgraham817,
See this link:
http://wikihelp.autodesk.com/Inventor/enu/2013/Vid
And more reading here:
I hope this helps.
Curtis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When placing your view (base view) select the box in the pic below. Change View Orientation. It will take you to the model and allow you to orient it in any way you want to view it in your drawing. There are a number of tools you can use. if you are talking about a flat surface you want square to the world in your drawing, I would use the "Look At" tool, then select a flat surface. Playa round with it until you get the view you want then hit the check mark "Finish Custom View", to return to the drawing.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Curtis
Once again you have thrown me the life jacket. Much appreciated, thanks again.
Randy
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi rgraham817,
It occurred to me after I posted that the custom view might be a better solution, but it looks like cbenner beat me to it. ![]()
See this link for the Show Me Video that follows cbenner's suggestion:
I hope this helps.
Curtis
