• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Drawing files, view problems.
    342 Views, 7 Replies
    01-02-2013 08:06 AM
    I am having an issue with drawing files. I have set views on assembly files. But on the idw file it is showing wrong views... And this is making problems when i am trying to give dimensions.  I have attached jpg files.
    Please use plain text.
    blair
    Re: Drawing files, view problems.
    01-02-2013 09:05 AM in reply to: tolgacankurt
    Is the item orientated correct to the 3D triad icon in the corner of the modeling window?
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Active Member
    01-02-2013 10:39 PM in reply to: blair
    no, it is different as seen on attached pic. How i can correct it?
    01-03-2013 09:36 AM in reply to: tolgacankurt
    The orientation of drawing views has nothing to do with the view cube, so even if you change the "Front" view on your view cube, it will have no effect on how it is displayed in a drawing.  The drawing looks to the part / assembly origin planes.
    In order to get your assembly to show properly in the drawing, you need to constrain it to the origin planes.  The positive Y-axis points up, and the positive X-axis points to the right when you are looking at the Front view.
    Active Member
    01-04-2013 05:15 AM in reply to: cwhetten
    Thanks for answers
    Active Member
    05-06-2013 07:12 AM in reply to: tolgacankurt
    But do you reconstraint the assembly to another origin axis?
    Sorry Im new to this
    Distinguished Contributor
    JamieVJohnson2
    05-06-2013 08:20 AM in reply to: cahoe
    RIGHT-CLICK ON THE DRAWING SPACE, SELECT GENERAL DIMENSION TYPE - PROJECTED (VS TRUE)
    jvj
    blair
    05-06-2013 08:44 AM in reply to: cahoe
    If the model is slightly off to the base-views in the View Cube, then you would want to un-ground the model (should be only the first part placed in the IAM that is automatically grounded, unless you have grounded more yourself). You can then ground any part (face or axis) to what every Origin Plane you wish.
    Win7-64
