• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    kaptenmjau
    Drawing add in title block
    194 Views, 3 Replies
    01-22-2013 07:57 AM
    Is there an add in or something for faster type in the title block in a drawing? Name, title etc?
     Right now the author and date are automatically  but when i save the file to for example to "D1234 hammer" it becomes the part number.
    I have to edit the title.
    I want to save the file to "D1234 hammer" and the partnumber to be "D1234" and title "hammer".
    IS there a add-in that I type the title and name and its auto fill the title block? Or do I have to create a custom title block so the drawing can understand to only to take the numbers from <part name> and the letters becomes <title>?
    Please use plain text.
    Distinguished Contributor
    LT.Rusty
    Re: Drawing add in title block
    01-22-2013 08:22 AM in reply to: kaptenmjau
    There's a few ways you can do it.
    I have a lot of the stuff in my drawing template set to pull iProperties from the parts or assemblies shown in the drawing to auto-populate the fields in the drawing.  This still, of course, requires me to completely fill out the information in the part or assembly iProperties.
    One of the guys that I work with created an iLogic form that gives him a single window where he can type in all the info that he wants from one window, and it will fill in everything without flipping through a bunch of iProperty tabs.  He also at one point created an add-in for Inventor back when we were using 2011 that did the same thing.  Unfortunately I don't know enough about iLogic or VBA to walk you through that one ...
    ___________________________________________________________
    Product Design Suite Ultimate 2013
    Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
    Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
    Valued Mentor
    mpatchus
    01-22-2013 08:24 AM in reply to: kaptenmjau
    Either create custom iProperties for the Part Number & Drawing Title, or utilize some of the existing iProperties and map them to your Title Block.  Once done, save the drawing file as your template.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Active Member
    kaptenmjau
    01-23-2013 12:13 AM in reply to: kaptenmjau
    Thx
    I will try with iLogic.
