• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Drawing Views Naming
    115 Views, 1 Replies
    11-16-2012 08:51 AM
    Hi All,
    I was wondering if it was possible to make my drawing views more streamlined.
    Currently, when I add a drawing view, the part number and scale is pulled from the part and scale chosen. So this is good; but I would like to get the styles editor to add the actual view of the part into its name.
    For example, if I choose the top view, the naming should look like the following:
    TOP VIEW
    XXXX-XX
    SCALE: X/X
    So basically I'd like to know if its possible to pull that information and display it in the naming text box. I would assume this is possible as all the other parts are possible, I dont see why this isnt an automatic default.
    Any help would be greatly appreciated.
    Cheers,
    VCS
    Please use plain text.
    Distinguished Contributor
    Re: Drawing Views Naming
    11-16-2012 12:30 PM in reply to: vsookrah
    Looking through Inventor I couldn't figure out how to do this.  So I did a search and found the following thread.
    http://forums.autodesk.com/t5/Autodesk-Inventor/Base-and-Projected-View-Label-Name-to-match-Orientat...
    They are using either VBA Macro or iLogic to change the view names.  I haven't messed around with this so I don't know how well it works.  Hope this helps.
    Stuart Kinzel
    Inventor 2013-64bit, HP EliteBook8740w Intel Core i5CPU 2.67 GHz
    8GB memory
    Windows 7 64bit
