• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Downloading Drawing Dimensions
    143 Views, 2 Replies
    10-07-2008 12:46 PM
    I want to download all drawing dimensions, and sequential number, into a First Article database to save typing. Please note; I do not want the parameters from the model.
    #1 2.245
    #2 3.075
    Etc.
    Is this possible?
    Please use plain text.
    Distinguished Contributor
    Re: Downloading Drawing Dimensions
    10-07-2008 08:20 PM in reply to: RussCan
    probably is possible with a little VB and a suitable intermediate file format. Can you post an example?
    Active Member
    10-08-2008 04:21 AM in reply to: RussCan
    Example; Dimension One: 2.375, Dim. Two: 3.500, Dim. Three: 5.125. , , , , From the parameter table you can list and download dimension count, actual dimension and tolerance. I want to get the same list except have it be the Drawing Dimension. I am making IPC cards (a dimensional checklist) for a First Article Report. , , , , Thank you.
