• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Do not show this message ever again
    512 Views, 15 Replies
    12-30-2011 06:57 AM
    How many times do I have to check that box for it to take effect?
    Bill Schmid
    Autodesk Product Design Suite Premium 2013
    Autodesk Vault Professional 2013
    Dell Precision T1650
    Windows 7 Professional SP1 64-bit
    Intel E3-1270 V2 3.5GHz / 16G RAM
    Nvidia Quadro 2000, Driver 276.42
    256 GB SSD
    Space Navigator, Driver Version 6.16.1
    Please use plain text.
    *Expert Elite*
    Re: Do not show this message ever again
    12-30-2011 09:05 AM in reply to: Bill.Schmid
    Which one?
    More information is needed.
    Attach screen capture or file and steps to reproduce the behavior.
    Some prompts can be turne off by going to Tools>Application Options>Prompts tab
    12-30-2011 09:09 AM in reply to: Bill.Schmid
    When you open an assembly and it asks if you want rebuild it.  Supposedly if you enable checking for recomputable updates on save it'll stop it from happening.  It doesn't.  This isn't listed in the list of prompts you can disable, either.
    Kind of like the check boxes to remember my password and keep me logged in on this site.  Sometiimes I wonder why I even bother to check them.
    Bill Schmid
    256 GB SSD
    Product Support
    01-03-2012 10:58 PM in reply to: Bill.Schmid
    Have you tried click the checkbox "Defer Update" at the appication Options?
    Application Options
    Then are you opening the Assem from Project?
    Yong Jing
    Product Support Specialist
    Frontline Technical Support, CSS. GCSO
    01-04-2012 05:24 AM in reply to: jingy
    I haven't tried that, but I'm not sure I want to.  What are the implications of having this checked?  If any components have changed, I do want the assembly to be updated to reflect all changes.  Defering makes me think it won't do this.
    Here's what the dialog box is telling me:
    Based on what this is telling me, I have enabled "Prompt to save for re-computable updates."  It was initally not enabled.  However, I never been prompted regarding any recomputable updates.
    Bill Schmid
    256 GB SSD
    Valued Contributor
    01-31-2012 06:24 AM in reply to: Bill.Schmid
    We've also encountered this infurating problem, and haven't been able to figure out a solution or workaround. In my company's case, this apparent bug is preventing us from storing the assemblies in a library and setting them to read-only.
    A couple of quick questions:
    Does your assembly utilize iParts and/or iLogic?
    If you save your assembly and then try to close immediately thereafter, do you get another prompt to save?
    Hope we can get this problem narrowed down a bit so that Autodesk guys can find a solution.
    01-31-2012 06:30 AM in reply to: SteveX82
    We do have iParts in the assembly and yes, I can save before I close and still get prompted to save.  Although the window that pops up with the list of what gets saved and what doesn't often has everything marked as "no."
    Bill Schmid
    256 GB SSD
    *Expert Elite*
    karthur1
    02-01-2012 06:17 AM in reply to: Bill.Schmid
    Bill,
    I think thats a new feature in 2012:smileysad:  If you check the "Never show again" box, it is only good for that session of Inventor.  For some reason, it doesnt remember this prompt setting when you close inventor.
    I posted about it too.   http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2012-missing-prompt/m-p/3247784#M419732
    Fortunately, I am still using 2011.  I just cant force myself to load 2012.
    02-01-2012 06:26 AM in reply to: karthur1
    I'd agree except that "Do not show this again this session" is one of the other prompts.  If I only wanted it to work for one session, I'd check that.  I usually did, but I got tired of seeing the message at all so I went for the "never" option.
    I hope they hurry up and fix some of this stuff.  I'd like to see it before I retire in 19 years or so.
    Bill Schmid
    256 GB SSD
    Valued Contributor
    02-01-2012 09:44 AM in reply to: Bill.Schmid
    Judging from your comment that most of the assembly components are listed as "No" when saving the assembly, I suspect that one of those read-only components may require updating. Inventor is dreadful when it comes to identifying which one (if any) of those components is actually out-of-date, so you will have to open up each individually and, after removing the read-only file property, update and save that file.
    The next time you open your assembly, you'll be prompted one last time to update it. Now when you save, it will be using the up-to-date versions of all the components, and it shouldn't prompt you again.
    My company's problem originated from some read-only iPart members that mysteriously required updated despite never having changed the factory. Inventor never gave us any warnings or "lightning bolt" buttons as the assembly level, so it required quite a bit of detective work to get to the root of the problem.
    Hope this helps,
    Steve
