• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Anthony
    Disappearing Frame Members
    118 Views, 7 Replies
    01-23-2012 08:37 AM
    I'm trying to generate frame members around a combination of 2D & 3D sketches, the preview is fine however when I click apply and OK it magically vanishes :smileymad:
    Everything is set up fine in the 'Insert Frame' dialogue box and the previews look spot on, any ideas what the problem is here, I've tried everything, Inventor is driving me mad !
    Please use plain text.
    blair
    Re: Disappearing Frame Members
    01-23-2012 08:48 AM in reply to: Anthony
    More information is required:
    System Spec's
    Operating System
    Version of Inventor
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.0 / 4.11
    Curtis_Waguespack
    01-23-2012 08:49 AM in reply to: Anthony
    Hi Anthony,
    From this and your previous post, I think you might be having some graphics card issues. You might take a moment to visit this link and try the suggestion to see if that is what is going on:
    http://inventortrenches.blogspot.com/2011/01/graphics-issues-application-options.html
    Posting a screen grab of the geometry in question might help also.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Anthony
    01-23-2012 09:01 AM in reply to: blair
    Inventor 2012 Professional
    Windows 7-64
    HP Intel 3.07GHz 12 GB RAM
    ATI FirePro V4800
    blair
    01-23-2012 09:24 AM in reply to: Anthony
    When you installed IV you followed the required installation procedure.
    Logged in with Administrator Privedges
    UAC is disabled (slider set to lowest position)
    Anti-Virus software disabled.
    You are using the most current Microsoft certified drivers for your graphics card.
    Try a simple F-G test. Create a simple IAM with a single line in a new IPT and see if you can create a F-G member.
    Win7-64
    Anthony
    01-24-2012 01:08 AM in reply to: blair
    Thanks for your advise. The software was installed by the IT company that we use, definitely not the way I would have had it but my hands were tied :smileyfrustrated:
    Therefore not sure if anti-virus was disabled on install, what is UAC ?
    I've done a fresh login today and fired up Inventor, attempted the F-G and again it vanishes out of thin air when I try to apply/ok it - also did a test as you suggested of a F-G on a basic line in a new IAM and it works fine.
    I have also found that applying a full F-G of my model in a new IAM work fine, then placing this IAM into my live model IAM allows the frames to be seen - very bad practice I know but at the moment it seems the only thing that works.
    Sometimes I pity Inventors buggyness :smileyfrustrated:
    blair
    01-24-2012 08:41 AM in reply to: Anthony
    UAC = User Access Control,
    Start>Control Panel>User Accounts>Change User Account Control Settings.
    Try setting the Slider to lowest setting: Also make sure you have at least Power-User for permissions, Administrator is better.
    Win7-64
    blair
    01-24-2012 05:06 PM in reply to: Anthony
    If the F-G is generated, but not visable, possibly look at your graphics card. Check that you are on the most current Microsoft Certified drivers.
    Also try "Compaibility" setting from within Inventor:Tools>Options>Application Options>Hardware>Compatibility
    Win7-64
