Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Dimensions causing unwanted angles
- Highlight
- Email to a Friend
The issue I have with Inventor 2010 is when i dimension a rectangle to be 44 in wide and 79 in height it becomes a slated rectangle. This event occurs on the work version of Inventor 2010. I have an educational version of Inventor 2010 at home and when I tried this same dimension rectangle at home it didn't have this issue. Is there a setting I need to turn off to fix this> Please help and thank you ![]()
Re: Dimensions causing unwanted angles
- Highlight
- Email to a Friend
Hi harris.1782,
You've likely toggled off your Constraint Inference and/or Constraint Persistence buttons.
See this link:
http://forums.autodesk.com/t5/Autodesk-Inventor/Is
I hope this helps.
Curtis
