• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Dimensions causing unwanted angles
    114 Views, 1 Replies
    07-09-2012 07:26 AM
    The issue I have with Inventor 2010 is when i dimension a rectangle to be 44 in wide and 79 in height it becomes a slated rectangle. This event occurs on the work version of Inventor 2010. I have an educational version of Inventor 2010 at home and when I tried this same dimension rectangle at home it didn't have this issue. Is there a setting I need to turn off to fix this> Please help and thank you :smileyhappy:
    Please use plain text.
    Curtis_Waguespack
    Re: Dimensions causing unwanted angles
    07-09-2012 09:22 AM in reply to: harris.1782
    Hi harris.1782,
    You've likely toggled off your Constraint Inference and/or Constraint Persistence buttons.
    See this link:
    http://forums.autodesk.com/t5/Autodesk-Inventor/Issue-with-2010-Inventor/td-p/3531308
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
