Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Dimensioni ng error in drawing. Inv 2013 pro.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I was just doing some drawings and found a very strange dimension.
See the attached pic. Its the dimension in section J-J (lower Left) It is supposed to be the same as the dimension in Section H-H but as you will see the dimesion it gives is a little strange ... lol
Andy M
Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
Re: Dimensioni ng error in drawing. Inv 2013 pro.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No idea what happened there. However, standard drafting practice is to dimension to centerlines of holes, not to section edges. That might give a better result.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thats a radius dim it putting on the cut edge. Section J-J is not truly vertical and the view it is cut from in not truly horizontal. Edit the view and rotate it so that the fins are horizontal. Edit the sec line J-J and add a vertical constraint and anchor it to the center of the hole.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sam, you are quite correct, in fact I had already added a centerline bisector and re-did both dimensions without error. I just thought it was strange to see such a dimension ... lol
karthur1, I very much doubt that it was picking up a radius, certainly not with that dimension. A 191metre radius is a bit big for these drawings ... lol
Andy M
