Autodesk Inventor
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*J, Jimmy
Dimension variable question
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
87 Views, 13 Replies
12-08-2002 05:09 AM
I know I asked this already but I wnt to ask again.
When I asked about global variables, Sean directed me to the tutorial.
Great. But I want to know this (yes/no):
example, in sketch mode, you can say d1=d3 and so on for that part file. but
in sketch, can you say d1_in_part2 = d8_in_part6 and so on? can you
refernece dimensions across different parts in sketch mode?
And obviously, these parts would be put into an assembly. Does anybody know
whether this can be done? (yes.no?)
*Munro, Neil
Re: Dimension variable question
Options
- Highlight
- Email to a Friend
12-08-2002 05:27 AM in reply to:
*J, Jimmy
Yes. In the part you want to reference dimensions from, rename the
dimension(s) you want to use in the other part with logical names. Then
check the Export Parameter checkbox next to these parameter(s). In the part
you want to use the dimensions from the other part, use the Derived
Component tool to derive the Exported Parameters from the first part. You
can elect to derive only the exported parameters. In a dimension edit box,
click the arrrow and select List Parameters to get a list of all renamed
parameters, including the parameters derived from the first part.
HTH
Neil
"Jimmy J" wrote in message
news:B2CD5C336FBEC59C1CE1801AC69659CB@in.WebX.maYI adrTaRb...
but
know
HTH
Neil
"Jimmy J"
but
know
*Keller, Kent
Re:
Options
- Highlight
- Email to a Friend
12-08-2002 07:03 AM in reply to:
*J, Jimmy
The only gotcha in this is you can't have some dims in one part1 drive
part2, and have some in part2 drive part1. Probably not as big of a deal in
parameters, but with skeleton modeling sometimes you find yourself wishing
you could do something like that.
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"Neil Munro" wrote in message
news:496E01531000E44E719B6B86CA8BF4B0@in.WebX.maYI adrTaRb...
part
> HTH
> Neil
Kent Keller
"Neil Munro"
part
> HTH
> Neil
*J, Jimmy
Re:
Options
- Highlight
- Email to a Friend
12-08-2002 08:56 AM in reply to:
*J, Jimmy
Is this for IV6 Only?
part
> HTH
> Neil
> but
> know
"Neil Munro"
part
> HTH
> Neil
> "Jimmy J"
> but
> know
*Fulford, Drew
Re:
Options
- Highlight
- Email to a Friend
12-08-2002 09:37 AM in reply to:
*J, Jimmy
No. I think it came in 5.0
- drew
Drew Fulford, B.A.Sc. Systems Engineer
Solid Caddgroup Inc, Burlington, Ontario
Phone: (905) 331-9670 Fax: (905) 331-7280
Check out my MDT & Inventor FAQ @ http://www.mymcad.com/
news:430C5DCDE56D01183B4EA792FBD5CA91@in.WebX.maYI adrTaRb...
> part
You
box,
> > HTH
> > Neil
file.
> > but
anybody
> > know
- drew
"Jimmy J"
> "Neil Munro"
> part
You
box,
> > HTH
> > Neil
> > "Jimmy J"
file.
> > but
anybody
> > know
*Dotson, Sean
Re:
Options
- Highlight
- Email to a Friend
12-08-2002 09:39 AM in reply to:
*J, Jimmy
I have been meaning to add this to the embedded and linked parameters
tutorial but keep forgetting...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
part
> HTH
> Neil
> but
> know
Sean Dotson, PE
"Neil Munro"
part
> HTH
> Neil
> "Jimmy J"
> but
> know
*J, Jimmy
Re:
Options
- Highlight
- Email to a Friend
12-08-2002 10:04 AM in reply to:
*J, Jimmy
Can somebody tell me :
1) what are logical names (is it like d1, d2 d3...)
2) where is the "check the Export Parameter checkbox next to these
parameters?"
3) where is the "click the arrow and select List Parameters...?"
there are bunch more but basically like how I would find these
commands/buttons/and checkboxes
Thanks.
And Sean, since you've got some time over the Christmas, maybe you should
add detail instructioned tutorial on this matter. That'll really be great.
part
> HTH
> Neil
> but
> know
parameters?"
Thanks.
"Neil Munro"
part
> HTH
> Neil
> "Jimmy J"
> but
> know
*Munro, Neil
Re:
Options
- Highlight
- Email to a Friend
12-08-2002 10:08 AM in reply to:
*J, Jimmy
Although embedded in a larger tutorial, here is a link to exporting and
deriving parameters: This tutorial was written for R5, so the UI is slightly
different than R6.
http://makeashorterlink.com/?H3AE223B2
Neil
news:3059FF6E38888793E7B6EDE85EA0D721@in.WebX.maYI adrTaRb...
> parameters?"
> Thanks.
great.
> part
You
box,
> > HTH
> > Neil
file.
> > but
anybody
> > know
different than R6.
Neil
"Jimmy J"
> parameters?"
> Thanks.
great.
> "Neil Munro"
> part
You
box,
> > HTH
> > Neil
> > "Jimmy J"
file.
> > but
anybody
> > know
*J, Jimmy
Re:
Options
- Highlight
- Email to a Friend
12-08-2002 10:21 AM in reply to:
*J, Jimmy
Thanks Neil!
I figured it out!!!
news:10E56724AF4F7EE0E53DDD901EEC3CA6@in.WebX.maYI adrTaRb...
slightly
> different than R6.
> Neil
> > parameters?"
> > Thanks.
should
> great.
Then
> > part
> You
> box,
renamed
> > > HTH
> > > Neil
tutorial.
> file.
> > > but
> anybody
> > > know
I figured it out!!!
"Neil Munro"
slightly
> different than R6.
> Neil
> "Jimmy J"
> > parameters?"
> > Thanks.
should
> great.
> > "Neil Munro"
Then
> > part
> You
> box,
renamed
> > > HTH
> > > Neil
> > > "Jimmy J"
tutorial.
> file.
> > > but
> anybody
> > > know
*Bliss, Charles
Re:
Options
- Highlight
- Email to a Friend
12-08-2002 02:18 PM in reply to:
*J, Jimmy
But how do I reference part parameters into an assembly. Simple
example, I have a ladder. The rails have a length. Based on this
length, I want to set the number of rungs in a pattern. How do I get
the length of the Rail into the assembly so I can calculate the rung
count?
I don't see a way of deriving into an assembly such that it will see the
exported parameters. Excel is not the correct answer.
I have already solved the problem with VBA but I am wondering if I have
overlooked something obvious.
>HTH
>Neil
>news:B2CD5C336FBEC59C1CE1801AC69659CB@in.WebX.maY IadrTaRb...
>but
>know
count?
>HTH
>Neil
>"Jimmy J"
>but
>know
