• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Keller, Kent
    Re:
    12-08-2002 03:05 PM in reply to: *J, Jimmy
    Can't say as I have actually done it, and I am sure your ladder example
    isn't as complicated as what you are really trying to do, but what if in
    your side rails the rung holes were a array, and in the assembly the rungs
    were arrayed using the feature pattern?
    Personally I think I would just do it as a Master Sketch 8^)
    Kent Keller
    Member of the Autodesk Discussion Forum Moderator Program
    http://www.MyMcad.com/KWiK/Mcad.htm
    "Charles Bliss" wrote in message
    news:3DF435CC.7030200@cbliss.com...
    > But how do I reference part parameters into an assembly. Simple
    > example, I have a ladder. The rails have a length. Based on this
    > length, I want to set the number of rungs in a pattern. How do I get
    > the length of the Rail into the assembly so I can calculate the rung
    > count?
    > I don't see a way of deriving into an assembly such that it will see the
    > exported parameters. Excel is not the correct answer.
    > I have already solved the problem with VBA but I am wondering if I have
    > overlooked something obvious.
    Please use plain text.
    *Bliss, Charles
    Re:
    12-08-2002 03:31 PM in reply to: *J, Jimmy
    The rungs are welded, no holes. I could have an array of points but
    that still wouldn't get the number of rungs required at the assembly
    level for a pattern.
    I presented a simple question so the problem could be understood. It is
    more like the quantity of rungs is based on the overall length of the
    ladder but with an OSHA minimum and maximum between the rungs.
    If you were doing this as a master sketch, how would you control the
    amount of rungs without having a part file which contained all the rungs
    in one part? The goal is to have one driving dimension for the ladder
    height, one for width and end up with an assembly with the correct
    amount of steps. The resulting assembly would then be brought into a
    weldment and welded together. The resulting BOM would show the correct
    quantity of rungs as well.
    >Kent Keller
    >>count?
    *Bliss, Charles
    Re:
    12-08-2002 03:47 PM in reply to: *J, Jimmy
    There is one way (sorta): I was just reading Kevin Schneider's post on
    "Pattern of a Pattern" and tried putting a feature on my "rail" then
    patterning the "rungs" on that feature pattern. That worked but still
    has a couple of drawbacks. First, it requires me to put features on my
    rail that I don't want and second, I couldn't do a feature pattern of
    workpoints which would have been my preference (they wouldn't add geometry).
    It sure would be nice if Inventor just allowed us to import parameters
    into assemblies just like it does from part to part.
    > is more like the quantity of rungs is based on the overall length of
    > the ladder but with an OSHA minimum and maximum between the rungs.
    > rungs in one part? The goal is to have one driving dimension for the
    > ladder height, one for width and end up with an assembly with the
    > correct amount of steps. The resulting assembly would then be brought
    > into a weldment and welded together. The resulting BOM would show the
    > correct quantity of rungs as well.
    >> rungs
    >> Kent Keller
    >>> count?
    >>> the
    *Keller, Kent
    Re:
    12-08-2002 11:13 PM in reply to: *J, Jimmy
    I agree completely with your statement below. Doesn't seem like it should be
    that hard, and it is a needed tool. Maybe as the Assembly features mature,
    they will also add the ability to derive into a assembly. And you are right
    about the master sketch, it would end up with one part file containing all
    the rungs.
    Kent Keller
    news:3DF44A81.1040400@cbliss.com...
