• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Caldwell, Larry
    Re:
    11-05-2002 04:27 AM in reply to: *Mears, Brian
    Which one is the arc length? Looks like the leader dim is the radius, no? If
    you change the angle, it still keeps the same dim.
    ~Larry
    "Sean Dotson" wrote in message
    news:F7066DFE262584F8DDEDF2584945C0F0@in.WebX.maYIadrTaRb...
    > oops hit enter too soon...
    > The vertical line shows the arc length
    > Sean Dotson, PE
    > http://www.sdotson.com
    > remove all #s from email
    > news:381D66E87B7A7998CE253DC130329302@in.WebX.maYIadrTaRb...
    > > There is an example in Cf on how to do it in part mode..
    > > Sean Dotson, PE
    > > "Drew Fulford" wrote in message
    > > news:6CA593A9E0B4568E85095008E333208F@in.WebX.maYIadrTaRb...
    > > > In an IDW its as easy as a RMB before placing the dim,
    > > > In an IPT its not doable without math formulas
    > > > - drew
    > > > Drew Fulford B.A.Sc. Systems Engineer
    > > > Solid Caddgroup Inc. Burlington, Ontario
    > > > Tel: (905)331-9670, Fax: (905)331-7280
    > > > Corporate: http://www.solidcadcam.com/
    > > > Member of the Autodesk Discussion Forum Moderator Program
    > > > Visit my MCAD website @ http://www.mymcad.com/
    > > > "Brian Mears" wrote in message
    > > > news:57DE2AC54F66919B2C27918860694D40@in.WebX.maYIadrTaRb...
    > > > > Is it possible in Inventor to dimension an arc's true length?
    Please use plain text.
    *Dotson, Sean
    Re:
    11-05-2002 04:30 AM in reply to: *Mears, Brian
    The vertical line is the arc length in both examples. In the first example
    change the angle or radius to get the length. In the second change the
    length or radius to get the angle...
    Sean Dotson, PE
    "Larry Caldwell" wrote in message
    news:3632CB02BE858051864756CCC8D2D404@in.WebX.maYIadrTaRb...
    If
    > ~Larry
    > > Sean Dotson, PE
    > > > Sean Dotson, PE
    > > > > - drew
    *Caldwell, Larry
    Re:
    11-05-2002 04:38 AM in reply to: *Mears, Brian
    Naturally I saw that only after I posted ... Duh! I picked on the dim ...
    sure'nuf ... it was named arc length.
    ~Larry
    news:7064FE7FB96C3A62932CFE3AC74368D8@in.WebX.maYIadrTaRb...
    example
    > Sean Dotson, PE
    no?
    > If
    > > ~Larry
    > > > Sean Dotson, PE
    > > > > Sean Dotson, PE
    > > > > > - drew
    *Bogan, Bill
    Re:
    11-05-2002 03:45 PM in reply to: *Mears, Brian
    Personally, I vote that the code for the drawing arc length be copied and
    used in the Part model
    IMHO.
    Bill Bogan
    news:962DDAF94B9E27DF72F57DF1799598B4@in.WebX.maYIadrTaRb...
    > ~Larry
    > example
    > > Sean Dotson, PE
    > no?
    > > If
    > > > ~Larry
    > > > > Sean Dotson, PE
    > > > > > Sean Dotson, PE
    > > > > > > - drew
