• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Mears, Brian
    Dimension arc length
    193 Views, 13 Replies
    11-05-2002 03:15 AM
    Is it possible in Inventor to dimension an arc's
    true length?
    Please use plain text.
    *Mears, Brian
    Re: Dimension arc length
    11-05-2002 03:16 AM in reply to: *Mears, Brian
    In a sketch, I mean.  I think I've done it on
    drawings.
    arc's true length?
    *Fulford, Drew
    11-05-2002 03:24 AM in reply to: *Mears, Brian
    In an IDW its as easy as a RMB before placing the dim,
    In an IPT its not doable without math formulas
    - drew
    Drew Fulford B.A.Sc. Systems Engineer
    Solid Caddgroup Inc. Burlington, Ontario
    Tel: (905)331-9670, Fax: (905)331-7280
    Corporate: http://www.solidcadcam.com/
    Member of the Autodesk Discussion Forum Moderator Program
    Visit my MCAD website @ http://www.mymcad.com/
    "Brian Mears" wrote in message
    news:57DE2AC54F66919B2C27918860694D40@in.WebX.maYIadrTaRb...
    > Is it possible in Inventor to dimension an arc's true length?
    *Mears, Brian
    Re:
    Crap. That's how I had to do it in MDT. Here's a vote for an 'arc length'
    sketch dimension in a future release....
    Brian
    "Drew Fulford" wrote in message
    news:6CA593A9E0B4568E85095008E333208F@in.WebX.maYIadrTaRb...
    > - drew
    *Maxey, Randall A.
    Re:
    11-05-2002 03:25 AM in reply to: *Mears, Brian
    "Here's a vote for an 'arc length' sketch dimension in a future release...."
    Amen, brother!
    :smileyhappy:
    *Dotson, Sean
    Re:
    11-05-2002 03:29 AM in reply to: *Mears, Brian
    There is an example in Cf on how to do it in part mode..
    Sean Dotson, PE
    http://www.sdotson.com
    remove all #s from email
    > - drew
    *Dotson, Sean
    Re:
    11-05-2002 03:33 AM in reply to: *Mears, Brian
    oops hit enter too soon...
    The vertical line shows the arc length
    Sean Dotson, PE
    "Sean Dotson" wrote in message
    news:381D66E87B7A7998CE253DC130329302@in.WebX.maYIadrTaRb...
    > Sean Dotson, PE
    > > - drew
    *Mears, Brian
    Re:
    11-05-2002 03:36 AM in reply to: *Mears, Brian
    I'd be working the other way... you use the angle and radius to find arc
    length; I would use radius and arc length to find the angle. Can you post
    an example of that? I just imported my adjustable arc from MDT, but I'd
    like to see your solution. Thanks...
    Brian
    news:F7066DFE262584F8DDEDF2584945C0F0@in.WebX.maYIadrTaRb...
    > Sean Dotson, PE
    > > Sean Dotson, PE
    > > > - drew
    *Maenpaa, Mike
    Re:
    11-05-2002 03:39 AM in reply to: *Mears, Brian
    I posted an example on 05/13/02 "Chord length of arc"
    See if that helps.
    Mike
    news:E70F095B5B48BC3067FE69421D094A67@in.WebX.maYIadrTaRb...
    > Brian
    > > Sean Dotson, PE
    > > > Sean Dotson, PE
    > > > > - drew
    *Dotson, Sean
    Re:
    11-05-2002 03:44 AM in reply to: *Mears, Brian
    see CF
    Sean Dotson, PE
    > Brian
    > > Sean Dotson, PE
    > > > Sean Dotson, PE
    > > > > - drew
