Inventor Forum
Dimension Arc Length
8 REPLIES 8
Message 1 of 9
justinpcaris
12490 Views, 8 Replies
I would like to dimension the arc length of a radius in sketch mode and i was wondering if this is possible. I am using Inventor simulation 2010.
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: justinpcaris
Techniques for controlling arc length via parameters have been discussed here in the past - if you can't find the solution post back and I'll see if I still have an old file example.
Message 3 of 9
PaulMunford
I put together a post on this that you might find usefull.
http://cadsetterout.com/inventor-tutorials/how-to-measure-dimension-and-specify-arc-length-in-sketch...
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Tags (2)
Message 4 of 9
justinpcaris
in reply to: PaulMunford
Awesome thanks for the help
Message 5 of 9
PaulMunford
You can now dimension Arc Lengths in sketches in Inventor 2013
Message 6 of 9
I'd CERTAINLY LIKE TO SEE HOW TO DIMENION ARCH LENGTHS IN THE SKETCHES.  I've BEEN LOOKING FOR A AHILE AND CANNOT SEEM TO FIND A HOW TO OR FIGURE IT OUT AS OF YET.
-M
Message 7 of 9
Hi @Mac_in_Rich_Baker,
  • Use the general dimension tool and select the arc
  • then before you click to place the dimension, right click
  • from the right click menu choose Dimension Type
  • from the dimension Type menu choose Arc Length
http://help.autodesk.com/view/INVNTOR/2017/ENU/?contextId=REDIRECT_ID_SKETCHGENDIM
edit: wrong link above, see this link:
https://forums.autodesk.com/t5/inventor-forum/how-to-dimension-an-arc-length/m-p/5706016#M552950
p.s. it's typically considered poor form to type in ALL CAPS
I hope this helps.
Curtis
Message 8 of 9
@Mac_in_Rich_Baker
Message 9 of 9
Success!!  Have a great weekend.
-M
