• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Accepted Solution
    Dimension Arc Length
    1598 Views, 4 Replies
    07-18-2011 08:59 AM
    I would like to dimension the arc length of a radius in sketch mode and i was wondering if this is possible. I am using Inventor simulation 2010.
    Please use plain text.
    *Expert Elite*
    Re: Dimension Arc Length
    07-18-2011 09:59 AM in reply to: justinpcaris
    Techniques for controlling arc length via parameters have been discussed here in the past - if you can't find the solution post back and I'll see if I still have an old file example.
    *Expert Elite*
    PaulMunford
    07-19-2011 05:45 AM in reply to: justinpcaris
    I put together a post on this that you might find usefull.
    http://cadsetterout.com/inventor-tutorials/how-to-measure-dimension-and-specify-arc-length-in-sketch...
    The CAD Setter Out Blog
    @CadSetterOut
    Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
    07-19-2011 07:35 AM in reply to: PaulMunford
    Awesome thanks for the help
    *Expert Elite*
    PaulMunford
    03-28-2012 11:47 PM in reply to: justinpcaris
    You can now dimension Arc Lengths in sketches in Inventor 2013
    @CadSetterOut
