• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Accepted Solution
    Difficulty with flat Pattern on ellipse
    229 Views, 5 Replies
    02-14-2013 07:55 AM
    First post here so hopefully it works out well. I'm having difficulty with a sheet metal part creating a flat pattern for it. The shape is an ellipse with the dimmensions shown in the second picture. When I attempt to create a flat pattern it just shows the side of the part. The sheet metal defaults are correct for the part and it was ripped to created a base point for the pattern. I need to create a DXF for manufacture. I would just use the flat pattern it gives me and mirror it twice to create a pattern but it doesnt factor in the radius of the part. Any thought on how to create a correct flat pattern for this item?
    Please use plain text.
    *Expert Elite*
    Re: Difficulty with flat Pattern on ellipse
    02-14-2013 07:59 AM in reply to: gta3005
    What version of Inventor?
    Do not sketch the thickness - Inventor will do that for you.
    Only need one ellipse.
    Contoured Flange (from the sheet metal tools).
    Rip
    Flat Pattern.
    Attach your ipt file here.
    Member
    02-14-2013 08:07 AM in reply to: JDMather
    Inventor Professional 2013
    Thanks for the quick response
    *Expert Elite*
    02-14-2013 08:09 AM in reply to: gta3005
    Let me give that another try - looks like Contoured Flange won't select an ellipse.   (and you left out some inportant information about the trims)
    *Expert Elite*
    02-14-2013 08:14 AM in reply to: JDMather
    I have to run - so not time to finish the part, but you get the idea
    see attached
    Member
    02-14-2013 08:17 AM in reply to: JDMather
    Thanks so much
