• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Vikestand
    Different component weights on same DWG??
    80 Views, 3 Replies
    12-07-2011 08:03 AM
    I did a search and couldn't find this question asked.
    When we do DWG we may have more than one Assembly on one individual DWG. When going to put the weights on the DWG throught the text/Physical Property insert yadayada it keeps referring back to the original assembly. Even after changing which component we want the info to be drawn from, it refers back to the original? Are we not doing this right? Program glitch? Not possible?
    Thanks in advance!
    Inventer 11
    OS: Windows 7
    Inventor 2011
    Intel Core 2 Duo 2.93GHz
    8GB RAM
    Windows 7 Pro
    Please use plain text.
    *Expert Elite*
    Re: Different component weights on same DWG??
    12-07-2011 12:43 PM in reply to: Vikestand
    I expect it works the same way as partlist/balloons and pulls the information from the first view model.
    I don't know if this will work but you might try a balloon style with a mass property then attach to the assembly you require, although more than likely it will pull the mass of the part it is attached to in that assembly.
    To get this I think you would need a view rep of the assembly as placed in the parent.
    Probably another case for one part/drawing or one assembly/drawing.
    Not much help, sorry.
    Employee
    jan.miskanin
    12-14-2011 03:00 AM in reply to: Vikestand
    this problem can by solved by using "Leader Text". "Text" is always related to first inserted view, "Leader Text" is related to the selected view.
    Jan
    Active Contributor
    Vikestand
    12-14-2011 05:52 AM in reply to: jan.miskanin
    Is there a way to pick out the individual assemblies by using this method? For example we may have 1 assembly made up of 3 other assemblies, each of those made up of "x" amount of parts. When I use this leader method it will only give me the weight of the individual part, not of one of the main three assemblies. Even tried changing the compenent to that assembly and still just gives me the weight of the channel instead of of the full frame.
    Inventor 2011
    8GB RAM
    Windows 7 Pro
