• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *A., Kirk
    Difference between Symmetric constraint and "mirror"
    323 Views, 3 Replies
    11-15-2002 01:12 AM
    I have ran across this from time to time. Here is the scenerio. Say that I
    have two points/circles with line dividing the two. I then chose to add the
    symmetric constraint, but get an error "adding this constraint will
    overconstrain the sketch". I don't understand why I get this. The two
    points/circles have no other constraints on them.
    The only way that I can get the two holes to be symmetric about the line is
    to delete one of the holes and then do a mirror about the line.
    Any ideas on why Inv. works this way? I am sure that it is something that I
    am overlooking, but it seems that if there are not any constraints on the
    points, adding the symmetric constraint should work.
    Inventor 5.3 sp2 / V6.0 sp....
    Win XP Pro
    P4, 2 Ghz, 512M
    Gloria II-64
    nVidia v6.13.10.4041
    1280x1024, 32 Bit
    Please use plain text.
    *Caldwell, Larry
    Re: Difference between Symmetric constraint and "mirror"
    11-15-2002 01:25 AM in reply to: *A., Kirk
    Are the circles dimmed, maybe? Mine works okay.
    ~Larry
    "Kirk A." wrote in message
    news:E9054786F3ACE44A67456F9C70DE17D3@in.WebX.maYIadrTaRb...
    I
    the
    is
    I
    > Win XP Pro
    > P4, 2 Ghz, 512M
    > Gloria II-64
    > 1280x1024, 32 Bit
    *Maenpaa, Mike
    11-15-2002 01:27 AM in reply to: *A., Kirk
    I just tried it, with no problems. Do you have dimensions on both holes?
    Maybe, you can post your file to CF.
    Mike
    I
    the
    is
    I
    > Win XP Pro
    > P4, 2 Ghz, 512M
    > Gloria II-64
    > 1280x1024, 32 Bit
    Active Member
    11-15-2002 05:46 AM in reply to: *A., Kirk
    I've had similar issues with the symmetry constraint. I was trying to center squares on reference lines though. I ended up having to use construction geometry in lieu of the symmetry constraint. I'm also using IV5.3sp2.
    -Matt
