• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Diameter symbol printing as 'Q'
    593 Views, 7 Replies
    11-26-2008 08:05 PM
    Hi, for a long while now we've been having trouble with all our IDW's, whenever we put a dimension or text with the diameter symbol it plots as 'Q'.
    Even in print preview it still appears as the diameter symbol, although when actually printed, it comes out as 'Q'. To combat this in the meantime we have firstly been creating PDF's which display the correct diameter symbol and then printing.
    i.e Ø30 on IDW prints as Q30
    on paper.
    We are using Autodesk inventor suite 2009.
    Any help appreciated
    Please use plain text.
    *Dennis Jeffrey
    Re: Diameter symbol printing as 'Q'
    11-26-2008 08:37 PM in reply to: Gamera
    Add this AIGDT.TTF font (attached) to your Windows Fonts
    folder.
    Dennis Jeffrey, Autodesk Inventor Certified
    Expert
    Autodesk Manufacturing Implementation Certified
    Expert.
    Instructor/Author/Sr. App Engr.
    AIP 2008 SP2, AIP 2009-SP1
    PcCillin AV
    HP zv5000  AMD64 2GB - Geforce Go 440, Driver: .8185
    XP
    Pro SP3, Windows XP Silver Theme
    href="http://teknigroup.com">http://teknigroup.com
    Member
    11-26-2008 08:45 PM in reply to: Gamera
    Thanks for the quick reply Dennis, but it says that the font is already installed?
    New Member
    11-27-2008 02:08 AM in reply to: Gamera
    I seem to remember having a similar problem a while ago - solved with a reinstall of the printer driver, even though the system was telling me that the correct, latest driver was installed. I persuaded the network guys to reinstall the network driver also, and that did the trick!
    (If memory serves correctly, it was a Hewlett Packard printer, not sure if that is relevant, but possibly worth mentioning...)
    Hope this helps,
    Helen
    Member
    12-01-2008 09:55 PM in reply to: Gamera
    Since we upgraded our server and PC's now running XP 64 bit everytime we log on it prompts us to find the correct printer drivers. So somethings definatly not right there although as far as we knew it wasn't affecting anything. Aparntly its going to be looked at in the near future, seems like it'd be the cause though. I'll post if/when the drivers are looked at and if it fixes it. Edited by: Gamera on Dec 2, 2008 4:59 PM
    Valued Mentor
    12-02-2008 07:56 AM in reply to: Gamera
    What happens if you type it? Your print driver may be overriding the AIGDT symbol with a Q but what if you use Ø? You could try a test with some text, maybe even try a couple of different fonts.
    (The Character Map says Alt+0216 but there is also a three digit code that I forget that gets you the same thing.)
    You could set up your styles to eliminate the automatic diameter symbol and make a new style for certain dimensions with a prefix/postfix and new hole notes. (I always preferred "DIA" anyway.)
    Active Member
    pburgeson
    01-18-2012 11:07 AM in reply to: dragonfire1
    I had the same problem and installed the Post Script (PS) version of my printer drivers instead of PCL.  Everythign prints fine now.
    01-18-2012 11:35 AM in reply to: pburgeson
    Thanks pburgeson for coming back and adding this info to an old post just incase someone else comes across it in the future.
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
