• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Accepted Solution
    Details from one sheet to another sheet in Inventor 2012?
    84 Views, 1 Replies
    10-02-2012 04:19 AM
    We run into a problem. We work on A3 size sheets and becourse we have a lack of plotters we can not exceed this size. What the next entails ... The details that we need to make understandable are something too small because there is just no space on the paper for us to make this really clear by eg using the scale 1:1.
    Our question is:
    -Can I place a created detail from Sheet 01 on to another sheet?
    -Can I have a reference in the partkist to this Sheet 03?
    With kind regards,
    OAB-Engineering
    Please use plain text.
    *Pro
    jletcher
    Re: Details from one sheet to another sheet in Inventor 2012?
    10-02-2012 04:43 AM in reply to: OAB-Engineering
    Yes in the browser just click and hold on the detail or section you wish to go on any other sheet and drag it to the other sheet in the browser.
    Drag till you get this bar..
    When you get this bar just let go of the mouse button and the view is moved
    Don't understand this one you wish for the part list to say it is on sheet2 or what ever the sheet it was places on?
    If so no there is no out of box way to do this. I  have a symbol that says FROM SHEET 1 and one that says SEE SHEET 2.. The sheet number is a prompt entry.
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
