• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Accepted Solution
    Design Assistant - Renaming Files
    399 Views, 14 Replies
    11-02-2012 08:12 AM
    I am using Design Assitant to rename files, but have had no luck with other referenced files.
    I have followed the Procedures from AutoDesk WikiHelp.
    Steps taken (summary)
    1. Open Top Assembly.
    2. In the top browser, I select the part and set Action -> Rename.
    3. Rename File.
    4. In the bottom browser, I select the file types for additional referenced files.
    5. I select (highlight) all the files.
    6. Click "SAVE"
    When I go to open the files, to check if the changes have been made, obviously to rename works on the Top Assembly,
    BUT for other additional refereced files, it doesn't.
    I am doing this in a Single User Project.
    Just wondering if there are other steps that need to be done to use Design Assistant properly.
    Thank you.
    Phoebus
    Please use plain text.
    Distinguished Mentor
    Re: Design Assistant - Renaming Files
    11-02-2012 08:37 AM in reply to: phoebus.biron
    Can you post a screen shot of DA the way you have it setup to rename the files?
    John Retzlaff
    Active Member
    11-02-2012 08:47 AM in reply to: john.retzlaff
    See "Screen Shot" of DA, attached.  Hope this is what you were asking for.  Thanks for the help.
    11-02-2012 08:57 AM in reply to: phoebus.biron
    Actually what I was hoping to see was how you had the Action and Name columns setup when you do the rename.
    Do you have a smaller assembly you can test with?
    John Retzlaff
    Active Member
    11-02-2012 10:40 AM in reply to: john.retzlaff
    Are you referring to the options that pop up when I right-click on the Action and Name columns?
    See the attachment.
    If not, please elaborate.
    11-02-2012 10:51 AM in reply to: phoebus.biron
    So after you have selected rename in the action, you will change the Name (this is the file name).
    Then hit save, and that component will be renamed.
    Is that what you are trying to do?
    John Retzlaff
    Active Member
    11-02-2012 11:10 AM in reply to: john.retzlaff
    Thats exactly what I am trying to do.  But I would also like the files to be reflected in all the referenced files.
    11-02-2012 11:18 AM in reply to: phoebus.biron
    So you are renaming a subassembly, and you also want to rename the components referenced by the sub?
    John Retzlaff
    Active Member
    11-02-2012 11:30 AM in reply to: john.retzlaff
    I would like to rename a part.  The new part (and file name) as I understand it, if renamed in DA, should be reflected in the top assembly, which the part is in.  And with DA, it can also be reflected in the referenced drawings.
    11-02-2012 11:33 AM in reply to: phoebus.biron
    So after you rename a part, then open the assembly drawing, the new part name is not showing up?
    I guess I am not really understanding the problem, sorry.
    John Retzlaff
