Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Derived surface not appearing in model
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
jmather_at_pct_dot_edu
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Got it, thanks.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi JD,
I sent you an email and wanted to confirm you received it.
Thanks again
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No, or at least I don't think so.
I typically get dozens of questions every day - I don't keep track of them.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I double checked the emai l address and it looks accurate. Do you mind checking your spam folder for an email with my name on it?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The given dataset contains composite surface (at least it looks like). The derived part command does not support derive of composite surface only surfaces and solid bodies. However derived assembly supports import of composite surfaces. You can try to insert the part into an assembly and derive the assembly, in the Others tab, expand the part instance node and include the composite surface.
Csaba
