• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    desilva2010
    Derived files - The resolved document is not usable!
    100 Views, 0 Replies
    12-06-2012 03:55 PM
    Inventor LT
    While referencing a derived file I attempted to make revisions to that file only to discover an Inventor error message.
    I thought I could delete the derived feature but Inventor created an unknown body. After the feature was deleted the body still remained visible in the part file and within the bodies tab. After deleting the body from the tab the file was still currupt.
    User mrattray (Mike Rattray) noted in my previous post:
    You can't fool Inventor by changing file names. It writes a unique hidden GUID key to every file it creates that it uses to tell files apart. In other words, if you have a part named part1a and you want to eplace it with a new part that was created you can't just delete the old part and stick the new one in the same folder with the name part1a because Inventor will see that the GUID doesn't match.
    Mike mentions how Inventor assigns a unique GUID key to each file. You can locate these GUID's in your Old Versions folder. As you can see, any part file can have multiple old versions of itself.
    In my case I needed to replace 3-720-7300-0 with 3-720-7300-0.0001. After doing so Inventor successfully opened what was once a currupt file.
    Please use plain text.
