• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Derive assembly in Inventor 2013 SP1
    372 Views, 3 Replies
    09-24-2012 10:54 PM
    We have found that after installing SP1 for Inventor 2013 is nearly impossible edit derived assembly. It takes very long time for open dialog of Derived assembly, without SP1 it takes approx. 2mins. for assembly of 20000 instances, with SP1 it takes more than 2 hours! This we are able to reproduce on each of our station. And more, there is still not corrected bug with save setting of hole patching range. This setting does not remember min and max value and after re open this dialog the range is set back to default value 10-9999mm.
    I have tried ti disable antivir  and all unnecessary services - no effect.
    Inventor 2013SP1, Win7SP1 64bit, Eset Endpoint Antivirus 5.0.2126
    Petr
    Please use plain text.
    Employee
    Re: Derive assembly in Inventor 2013 SP1
    09-25-2012 02:14 AM in reply to: petrxn
    Hi Petr,
    When using the common assmebly to make derive, it looks fine when editing the derived assembly. Maybe it is related to the dataset you have. So could you attach the dataset or send me @ river-yijiang.cai@autodesk.com for further investigation?
    River Cai
    Quality Assurance Team
    Valued Contributor
    09-25-2012 07:22 AM in reply to: Yijiang.Cai
    Hi River,
    thank you for response. I have sent you email with link to the model and with short description.
    Best regards
    Petr
    Distinguished Contributor
    Ryan.Martinez
    09-25-2012 01:00 PM in reply to: petrxn
    Uninstal SP1 autodesk just took it down due to memory errors
    Product Design Suite 2013
