• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Accepted Solution
    Deleting Family in created Library
    107 Views, 2 Replies
    11-16-2012 08:59 AM
    I created a new library to publish some profiles we use in our company. But some profiles didin't work exactley as they were supossed to do. So i tried to delete some of the families i created. But the Inventor doesn't allow me to do so. The button to delete the family just is in gray, and i can't use it. How can i delete the families i created?
    Please use plain text.
    *Expert Elite*
    cbenner
    Re: Deleting Family in created Library
    11-16-2012 09:58 AM in reply to: Lenfers
    In your library view, you are set to Merged View.  you cannot delete in this view.  Click in there and find your library, then you should be able to delete.  merged view means you are viewing your library plus the standard libraries.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    New Member
    11-16-2012 11:26 AM in reply to: cbenner
    Thanks. It worked just fine!
