• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Accepted Solution
    Delete userparameter with ilogic
    520 Views, 1 Replies
    01-09-2012 02:22 AM
    Dear,
    I know how to add user parameters with ilogic, but i would like to dete them as well. I've tried to use the delete option as mentioned in the API help but I cann't get it working in ilogic.
    any one a suggestion, this is how i create a parameter:
    Format:HTML Format
    Version:1.0
    StartHTML: 165
    EndHTML: 3855
    StartFragment: 314
    EndFragment: 3823
    StartSelection: 314
    EndSelection: 314
    DimoDocAsPartDocument=ThisDoc.Document'of : oDoc as AssemblyDocumment = ThisDoc.Document
    'nummerieke parameter
    Try
    prop=oDoc.ComponentDefinition.Parameters.UserParameters?.item("nummer")
    Catch
    newprop=oDoc.ComponentDefinition.Parameters.UserParameters?.AddByExpression("nummer", "100", "mm")
    EndTry
    greetings,
    theo
    Please use plain text.
    Valued Contributor
    Re: Delete userparameter with ilogic
    01-09-2012 02:30 AM in reply to: theo.bot
    Found the solution:
    Format:HTML Format
    Version:1.0
    StartHTML: 165
    EndHTML: 1602
    StartFragment: 314
    EndFragment: 1570
    StartSelection: 314
    EndSelection: 314
    DimparamAsParameter
    param=oDoc.ComponentDefinition.Parameters.Item("G_L")
    param.Delete
    Maybe it's intresting for other users!
    Kind regards,
    Theo
