• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Accepted Solution
    Delete Part Fillet Feature??
    145 Views, 2 Replies
    12-07-2011 08:40 AM
    Hello Experts!!
    Can you delete part of a  fillet feature? While still keeping part of it & adding to it.
    I have a fillet feature with 2 fillets to a part. One is in the wrong place.
    The Feature Fillett1 if you edit it, you will see what I mean.
    Keep the middle one. Both fillets are 0.25"
    Replace the bottom fillet to the top corner.
    I would like to keep the Feature in the order it is in, if possible.
    I am using Inventor 2012.
    Kind regards
    A Student.
    Please use plain text.
    *Expert Elite*
    Re: Delete Part Fillet Feature??
    12-07-2011 08:46 AM in reply to: 20112679
    Edit the Fillet feature
    Ctrl Click the edge you don't want filleted.
    (you could now select the edge you do want filleted - but I wouldn't do that as you have already created some dependencies on that edge)
    Select OK and then add the fillet at the bottom of the history tree.
    *Expert Elite*
    12-07-2011 08:47 AM in reply to: 20112679
    You can edit the feature and use the "CRTL" button to deselect and edges you don't want.
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
