• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Employee
    Re: Default hole settings - termination
    09-28-2011 06:49 PM in reply to: rimo625
    The Termination setting has been addressed in 2012 SP1. Now, the default termination is Through All when start hole feature at the first time. And after changing the termination to other types, it will keep that customized setting from session to session.
    Please use plain text.
    *Expert Elite*
    MariaManuela
    09-29-2011 02:34 AM in reply to: sysh
    I'm sorry to contest. But im running Invpro2012 + SP1 and the default hole settings is exacly what the image shows.
    If i change the termination type...yessss i confirm you that the settings are the same in new hole feature or even in new component.
    But if i restart Inventor the dialog box displayed has the same default setting with Distance in termination type.
    I realized that this has not happened with SP1. Im wrong?
    Maria Manuela Pinho
    Application Enginner
    Cadtech.Asidek | Autodesk Gold Partner
    http://cadtech-asidek.blogspot.com/
    www.cadtech.pt | www.cadtech.es | www.asidek.es
    Autodesk Inventor Professional 2013
    Windows 7 Professional 64-bit
    Employee
    09-29-2011 08:35 PM in reply to: MariaManuela
    I check that termination setting on three machines with 2012 SP1. But I can't see the issue you said. So please make sure SP1 was installed successfully on your machine.
    From the behavior you said, the other possibility I guess is that you installed a hotfix about that termination setting after SP1. If this is true, then you need to reinstall SP1.
    Other comments:
    From Inv 2012, the default termination type was changed to Throught All. But we got some complains that they wanted Distance as the default type. So at that time, we provided that hotfix for them. And it is only for those people who want Distance as the default.
    After SP1 was released, that hotfix was NOT needed anymore. Especially, you should NOT install that hotfix after installing SP1.  On SP1, when you start hole command at the first time, the default termination type is Throught All. Then you can change it to other types. And it will keep that customized setting for ever.
    Distinguished Contributor
    09-30-2011 05:08 AM in reply to: sysh
    I'm hoping this 'remember last' also extends to the drill point angle as the entire world does not neccesarily use 118° (135° here).
    KState92
    Inventor Series 2010 SR SP4
    Windows 7 64 bit - SP1
    8 GB Ram
    Quadro 2000
    Employee
    10-09-2011 11:03 PM in reply to: kstate92
    Thank you for posting the issue about Drill Point Angle setting. I've logged it in our tracking system as a wish list item. We will consider it in the future.
