• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Def Points layer
    147 Views, 5 Replies
    11-08-2012 02:54 PM
    How can I delete a def point layer after the program says i can not?
    Please use plain text.
    Valued Mentor
    jclaidler
    Re: Def Points layer
    11-09-2012 06:30 AM in reply to: jrittenhouse
    Defpoints in 'Inventor'?
    _______________________________________________________________
    ITO - Application Management
    Factory Design Suite Ultimate 2012
    AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
    11-09-2012 09:02 AM in reply to: jclaidler
    Def points in AutoCAD.
    Valued Mentor
    jclaidler
    11-09-2012 09:14 AM in reply to: jrittenhouse
    This is the 'Inventor' group.  But why would you want to delete 'defpoints'?  You can't delete that layer anyway, AutoCAD uses it for certain objects created.
    Distinguished Mentor
    ampster
    11-09-2012 10:28 AM in reply to: jrittenhouse
    one way is to rename defpoints then purge.
    Valued Mentor
    jclaidler
    11-09-2012 10:31 AM in reply to: ampster
    Yes, you can rename the layer.  But once a dimension is placed, defpoints is created again.
    Best option, leave it alone.
