Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Decal Command and iParts-iAs semblies
- Highlight
- Email to a Friend
i have created an iPart with various mambers with different labels created with Decal command. (I use Inv2012, Win7)
(Each member has Decal feature suppress or compute dependeng on his version).
Until now, fine.
Then i have created an Assembly and when i insert the iPart (with the labels version) no label appears..none of the iPart member show the label, works fine for other changes (measures, colors, properties, etc), but fail with Decal.
I can see the label only during the preview (befor fixing the part in the assembly, then it dissapear).
I have test it on notebooks, and workstation. No graphic card problem.
Is it a limit of the Decal feature?
Do i wrong somewhere?
Is it a bug issue?
Thanks for Support
You Can Download an example fuploaded by me here :
http://dl.dropbox.com/u/63643836/Test%20Decal%20iP
Re: Decal Command and iParts-iAs semblies
- Highlight
- Email to a Friend
You placed the decal on iPart factory, but when you placed it into your assembly, it was a ipart member derived from the factory file. Since Inventor will ignore decal features when derive it, so you can't do it in that way.
You can use iLogic to get similar result, then choose place iLogic component in your assembly.
Jingyi Liu
Quality Assurance Team
- Highlight
- Email to a Friend
Thank you Liu!
