• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    CAD-One
    Re: DXF
    09-30-2012 05:50 PM in reply to: BLHDrafting
    Great input !
    Thanks for sharing.
    C1
    Inventor Professional 2013
    Vault Collaboration 2013
    Please use plain text.
    Re: DXF
    10-11-2012 01:47 AM in reply to: BLHDrafting
    Please find the attached file, 'dxf text.ipt'. I tried using derived and thicken option, but I got problems with flat pattern and cuts.
    Distinguished Contributor
    brendan.henderson
    Re: DXF
    10-11-2012 08:48 PM in reply to: satbir.sohal
    There is a file test.ipt missing from this.
    Brendan Henderson
    CAD Manager/Product Development Manager
    HP Z420 Workstation, Windows 7 x64, 64 GB Ram
    Intel Xeon E5-1620 @ 3.60 GHz, ATI FirePro V7800 2 GB
    3*Dell 2007Fp monitors, SpacePilot
    Inventor 2013 PDS Premium & Service Pack 1.1 with Update 2
    Vault Workgroup 2013 with Update 1
    Re: DXF
    10-12-2012 12:15 AM in reply to: BLHDrafting
        Please find the attached file 'test sample.ipt'
    Thank you
    BLHDrafting
    Re: DXF
    10-14-2012 02:04 PM in reply to: CAD-One
    Gday.
    Attached is a zip file of a dataset I created. Have a look at TEST_PART_SOLID.ipt first to see how I created the negative of the shape I wanted (you could use a positive also-depends on your needs). Then look at TEST_PART.ipt to see how I used the DERIVE and then THICKEN tools to create the sheetmetal part. You will need to review the earlier video about derive and thicken. I don't know why you are having trouble. I see that the Cut1 produced dodgy flat pattern results. This is why you should either
    1. Create a solid template (solid could be extruded surface or solid) or
    2. Use Flat Pattern tools.
    Best of luck.
    Brendan Henderson
    Web www.blh.com.au
    Twitter @BLHDrafting
    Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
    ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD
    Inv R2013 PDS SP1.1 Update 2, Vault 2013 Workgroup Update 1
    Re: DXF
    10-15-2012 03:42 AM in reply to: BLHDrafting
    Thank you Brendan. I have now understood the concept. The geometry is now perpendicular to the sheet. Unfortunately, my CAM software (RADAN), still does not auto tool the produced geometry. The circle and hex do not produce a smooth curve or lines. I might need to ask CAM guys for support.
    Thank you for your assistance.
    Satbir Sohal
