• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    DXF
    379 Views, 15 Replies
    09-20-2012 03:51 AM
        I made a cylinder which is in the attachment. When I flat pattern produce its dxf file, I am not able to get correct geometries. When I zoom into the dxf file, I see that the inner hexagon and circles project irregular shapes and are not concentric.
    Please use plain text.
    mrattray
    Re: DXF
    09-20-2012 05:25 AM in reply to: satbir.sohal
    The flat patern is corect, it's your folded model that's wrong. The way you cut those, well, cuts, is not perpendicular to the face. I suggest you remodel this using a contou flange, then the unfold feature. Make all of your cuts after the unfold feature, then follow it up with a refold. This will cause the edges of the cuts to stay perpendicula to the material and allow the expected flat pattern to be created.
    Mike (not Matt) Rattray
    Re: DXF
    09-20-2012 05:43 AM in reply to: mrattray
    Thank you for the reply. I tried that before, but its a lengthy procedure and I had to manually calculate the circumference and pitch and then convert them into rectangular pattern. Is there no alternative option where I can get these done quickly ?
    mrattray
    Re: DXF
    09-20-2012 05:46 AM in reply to: satbir.sohal
    You could just enter a formula intot the rectangular pattern spacing instead of hand calculating it. This way it will be linked to the radius of the cylinder.
    *Pro
    jletcher
    Re: DXF
    09-20-2012 05:52 AM in reply to: satbir.sohal
    Can you post a pic of the part I cannot open your part I will not install 2013 again.
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    mrattray
    Re: DXF
    09-20-2012 05:56 AM in reply to: jletcher
    Re: DXF
    09-26-2012 03:08 AM in reply to: mrattray
        Can you please make a similar cylinder using contour flange and send me the ipt file. as I am unable to get it.
    Active Member
    Re: DXF
    09-26-2012 09:27 PM in reply to: satbir.sohal
    Another option I regularily use is to create a solid of what I want (including the angled cut and the holes/projections) and use the Derive the Thicken method from the sheet metal file. Works great and gets all of the cuts perpendicular with the sheet metal face.
    Brendan Henderson
    CAD Manager/Owner
    BLH Drafting Services
    Web www.blh.com.au
    Twitter @BLHDrafting
    Inventor 2012 PDS Premium SP 2 and Vault 2012 Update 1
    Please mark as Accepted As Solution or give Kudos.
    CAD-One
    Re: DXF
    09-27-2012 04:24 AM in reply to: satbir.sohal
    BLHDrafting- Sounds interesting. Can you eloborate " derive the thicken method"
    C1
    Inventor Professional 2013
    Vault Collaboration 2013
    Active Member
    Re: DXF
    09-30-2012 04:46 PM in reply to: satbir.sohal
    No problems.
    Here is a link to a short video of using the Derive and Thicken method. You basically make a positive (or negative) and import this shape as surfaces, then thicken the surfaces you want. Any protrusions you have in the solid can also be included in this method. Good luck.
    http://screencast.com/t/VLBL762Cnck
    Brendan Henderson
    CAD Manager/Owner
    Web www.blh.com.au
